PC Build for Friend!
Go to solution Solved by Herman Mcpootis,
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor ($139.79 @ B&H)
Motherboard: MSI PRO B550M-VC WIFI Micro ATX AM4 Motherboard ($109.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($64.97 @ Amazon)
Storage: Silicon Power XS70 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($114.99 @ Newegg Sellers)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6800 XT 16 GB Video Card ($579.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($94.99 @ Amazon)
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Newegg Sellers)
Total: $1204.71
Generated by PCPartPicker 2023-01-18 19:55 EST-0500
Budget (including currency): $1,200
Country: USA
Games, programs or workloads that it will be used for: Fortnite, Rumbleverse, Naraka, etc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Start buying parts in 1-2 weeks. ALSO seeking a 5 or 6 pack of 120mm Case Fans
Hello! I previously received advice on an older post but decided to lower the budget. I’m set on the Case and Graphics Card. Looking for verification on everything else.
PC Part Picker List
Thank you in advance!
https://linustechtips.com/topic/1482344-pc-build-for-friend/
No idea why you're set on that GPU, it's pretty crap value compared to a 6650XT/6700.
https://linustechtips.com/topic/1482344-pc-build-for-friend/#findComment-15757782
Total: $1204.71
https://linustechtips.com/topic/1482344-pc-build-for-friend/#findComment-15757806
Total: $1204.71
Thank you for the build! Do you have another GPU in mind since that one is now $900+?
https://linustechtips.com/topic/1482344-pc-build-for-friend/#findComment-15758848
You'll have to drop down to an RX 6800.
https://linustechtips.com/topic/1482344-pc-build-for-friend/#findComment-15759538
