1 minute ago, NoahPCBUILDER said:
my pc is the nzxt h510, ryzen 7 5800x, and h100 elite capelix 240mm. my fans on the radiator are facing in. my temps while playing rust are in the low 70's. this was my first time using aio and was wondering if this was fine. (idle is 48c)
Yes those temps are perfectly fine.
https://linustechtips.com/topic/1481903-help-my-cpu-is-hot/#findComment-15754581
