Budget (including currency): £1500 ($1700)
Country: UK
Games, programs or workloads that it will be used for: Gaming: League of Legends, CSGO, Warzone, Valorant
Other details: I can probably add a couple hundred more to the budget if the upgrade is worth it. I want to game and stream on this build. I have a rough build right now but not sure what is the best as I am new to this.
Case: Lian Li Lancool-215
CPU: Intel i7-12700k (Do i need a air cooler or liquid cooling?)
GPU: GeForce RTX 3070 8GB LHR
Motherboard: MSI Pro Z690-A DDR4
RAM: 32GB (2x16GB) DDR4/3600mhz Corsair Vengeance Pro SL RGB
PSU: Corsair TX850M 850W 80+ Gold
NVME Drive: 1TB Samsung 990 Pro M.2
Any help, advice and recommendations would be appreciated.
https://linustechtips.com/topic/1481850-building-a-pc/
What do you have for a monitor?
https://linustechtips.com/topic/1481850-building-a-pc/#findComment-15754251
What Rez?  Looking it up is failing. I’m trying to figure out how big your video card needs to be to saturate your monitor.  You might need a bigger monitor or a smaller graphics card
https://linustechtips.com/topic/1481850-building-a-pc/#findComment-15754793
