New PC build suggestions.
Go to solution Solved by Ryuikko,
This could be considered
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor ($229.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler ($39.90 @ Amazon)
Motherboard: MSI PRO B650-P WIFI ATX AM5 Motherboard ($219.99 @ Best Buy)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory ($128.99 @ Newegg)
Storage: Kingston KC3000 1.024 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($96.70 @ Amazon)
Video Card: MSI GAMING Z TRIO Radeon RX 6800 16 GB Video Card ($503.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($94.99 @ Amazon)
Power Supply: Phanteks AMP 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Newegg)
Total: $1413.55
Generated by PCPartPicker 2023-01-13 17:22 EST-0500
Budget (including currency): $1500
Country: US
The games, programs, or workloads it will be used for : Minecraft with 200 mods and with high-end shaders.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am upgrading from a Lenovo S145 (AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx 2.60 Ghz, 8.00 GB RAM, AMD Radeon(TM) VEGA 3 graphics, 237 GB storage. I think I will need at least a 3060, and at least 60 fps.  At least 1440p.
https://linustechtips.com/topic/1481189-new-pc-build-suggestions/
23 minutes ago, Scorpion_3381 said:
Your link only takes us to Build a PC page. Use something like PC Part picker Choose Your Parts - PCPartPicker
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
Country: US
This is a good build https://pcpartpicker.com/list/nHN9H2
Main RIG
-Jim Rohn
Not including peripherals.
Main RIG
-Jim Rohn
That looks alright, but I’d probably get a smaller cooler with a full ATX motherboard. The dark rock pro 4 will end up being basically the same size as the mobo, which will look wrong in an ATX case
My Fault...
Main RIG
-Jim Rohn
Just now, Scorpion_3381 said:
sorry my bad
u can use it to pick a price and let it do the rest!
Build redux isn't that good of a PC builder
Main RIG
-Jim Rohn
Total: $1413.55
1 hour ago, Scorpion_3381 said:
no lol
only like 3 price points
lmao
next to usless
but it had the price point that he was trying to hit.
If you don't quote people, they don't know you replied to them.
The build redux has a 5800x and a 3060 for $1500 though. As @Ryuikkopointed out, you can have a much better cpu/gpu combo in that price point. If you're fine buying used you can even comfortably fit a 3080 in at $1500.
Them having a motherboard with no built in Wifi, then throwing a $30 wifi adapter also isn't doing favors when you can get equivalent motherboards for less than just the motherboard with WiFi built in.
https://www.amazon.com/ASUS-TUF-B550-PLUS-Motherboard-Addressable/dp/B08F9LP42S
That hyper 212 evo isn't going to be that happy with having a 5800x under it. I wouldn't recommend that cooler with that CPU, but just to give you an idea of how much they're over charging for parts here's this. Subtract the $100 for their build and warranty and it's still $150 cheaper. I don't know why their charging for 4 MF fans when the case comes with 3.
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($236.00 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO V2 62 CFM CPU Cooler  ($39.99 @ Amazon)
Motherboard: Asus PRIME B550-PLUS ATX AM4 Motherboard  ($124.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($57.99 @ Newegg)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($74.98 @ Amazon)
Video Card: PNY VERTO GeForce RTX 3060 12GB 12 GB Video Card  ($359.99 @ Amazon)
Case: Cooler Master MasterBox TD500 Mesh w/ Controller ATX Mid Tower Case  ($129.99 @ Amazon)
Power Supply: Corsair CX750M (2021) 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($89.99 @ Best Buy)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit  ($107.99 @ Other World Computing)
Case Fan: Cooler Master MasterFan MF Halo 47.2 CFM 120 mm Fan  ($23.90 @ Amazon)
Total: $1245.81
Generated by PCPartPicker 2023-01-13 18:46 EST-0500
If someone insisted on having a 5800x, but didn't want to buy anything used, I'd do something that looks more like this.
CPU Cooler: Vetroo U6 Pro 58.2 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: Asus TUF GAMING B550-PLUS WIFI II ATX AM4 Motherboard  ($139.00)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($65.98 @ Amazon)
Video Card: Asus DUAL OC V2 GeForce RTX 3070 LHR 8 GB Video Card  ($569.99 @ B&H)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  ($42.99 @ Amazon)
Total: $1459.91
Generated by PCPartPicker 2023-01-13 18:52 EST-0500
If someone was comfortable with used, you can get a 3080 in that build.
That being said, a zen 3 build at the $1500 price point makes 0 sense to do.
You can go with a faster Intel cpu, and an AMD gpu that will out perform in pure rasterization and at 1440p and lower than a 3070ti while saving $100.
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($247.99 @ Amazon)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($54.00 @ Amazon)
Motherboard: Gigabyte B660 DS3H AX DDR4 ATX LGA1700 Motherboard  ($183.72 @ MemoryC)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($48.99 @ Newegg)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ B&H)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($88.98 @ Newegg)
Power Supply: MSI MPG A850GF 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($122.36 @ Amazon)
Total: $1375.02
Generated by PCPartPicker 2023-01-13 18:56 EST-0500
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
