SSD selection help
Go to solution Solved by ewitte,
4 hours ago, lotus10101 said:
Where do we fine the QLC/TLC spec anyway? never seen it directly in descriptions
It's normally easy to find if you search for the model number.  If it isn't explicitly specified or reviewed a tell-tale sign is write performance after the buffer drops down to really low numbers like 300MB/s or worse.  Most TLC drives will never drop under 1GB/s (higher for higher capacity drives).
They will also specify much lower TBW numbers a TLC drive may be 1000TBW while QLC may be even 100-200TBW.
1 hour ago, AyaanMAG said:
Is Western Digital black really that necessary for  gaming? The WD black is 6k rs [$100] more expensive than the blue for the same capacity, so my question remaining. Do I need black over black? What's the most impact will it have? My use case is maybe some gaming and OS
I run a Blue SN570 M.2 for boot / gaming and it does fine for me. I'm more of a casual gamer though, mostly BeamNG.drive and American Truck Simulator. So it depends on your use. Quite a few gameplay videos have shown little to no difference beyond 3,400 mbps.
For someone that records / streams, maybe has a 3090ti and plays mostly top-shelf titles like Elden Ring, etc., the Black might be worth it. There is an SN770 that's not as pricey as as the SN850. But be aware I've also seen reviews showing the PCIe4 drives run 90C-100C, which I didn't like, hence my reason for going with the PCIe3 SN570. So I would recommend a heat sink with the Black. If your board includes one, so much the better. My Asus Tuf B550-PLUS does.
However, I can tell you that my WD Black HDD (aux storage) kicks the stuffing out of the WD Blue HDD in my 1700.@Mark Kainecan attest to this as well. He's posted screenshots of 240 mbps with an external D10, I have an 8TB 256MB cache internal that's doing 220 mbps at nearly 60% capacity. They're available in 64MB, 128MB, 256MB cache sizes.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15749769
Mostly depends on your use case, if your a casual gamer and not really pressed for time where and extra 30 seconds (large games) might count then WD blue is more than fast enough, I have a WD Blue nvme SN500 and its been great, by no means are the blues top performers in there class but their still more than twice the speed of normal SSD and generally reliable for long term operation
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15749775
Here is what I go for
- dram buffer
- NOT QLC.  I despise current QLC offerings.  That doesn't mean something decent will not be eventually released.
- Make sure it is a name brand controller (Phison is ok).
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15749776
- dram buffer
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15749794
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15750184
I checked it's tlc and people on reddit said it's quite alright. I'm going with it thank you for your help
https://linustechtips.com/topic/1481133-ssd-selection-help/#findComment-15752409
