t5610 T5610 power supply upgrade from 825W to 1300W?
6 hours ago, NixTheFolf said:I would do a diy setup but I don't have much money and spent most of my budget on the T5610 already and this is the final upgrade that I could make to it that would fit it perfectly to my needs.
I chose for a Tesla K80 mainly for its price to VRAM at 24GBs for $90~ as the workloads that I mainly use fits perfect for the card for both the price and the performance it offers.
I would love to change the distribution plate to something like in the T7610 as it both natively had the 1300w PSUs in it and extra VGA rails, but the only two issues is the size of it fitting in my case, though I would not mind cutting a hole on the side for it to fit if it is the case, and second is the connectors to all the components I am not sure go with it, and if they have adapters if they don't.
Below is the T5610 PDB in my current system:
And below this is the T7600's PDB which has more VGA ports which fit, but I am not sure for the CPU connectors, I believe the motherboard connector is compatible but not entirely sure as I could not find much info about the compatibility of the connectors:
Right I forgot the t7610 does a weird dual 24pin thingy which isnt adaptable.
Sadly I dont reallt know of a way to get that to work as adapters dont seem to exist
