Hay guys I have an issue related to my motherboard gigabyte b450 m, when I unplug the power the motherboard start boot loop thur the cpu,dram,vga lights on the board,it will only post once I press the power and rest button at the same time a few times, then would post normally unit I unplug power. Does anyone know why I’m having this issue or a solution, i have swaped my cpu,
https://linustechtips.com/topic/1479909-temperamental-motherboard-issue/
Sounds like like flaky power switch or incorrect front panel header wiring. Does it start normally pressing only the reset button?
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
i double checked wiring, it turns on but boots cycles thur post codes cpu dram vag and wont post unless i press the rest and power button, and anytime after that it will post normally unit power is discounted, then would go back to boot looping
@Temppy_First, you made a little typo there you might want to correct (in the diag light part, usually not a big deal, think about it).
Kinda sounds like flaky power / reset switches, or possibly a PSU issue. Weak capacitors can bleed down when turned off, causing hard starting.
i have swapped psu and used a different case this more likely motherboard issue im just going to swap the rest of parts into a different setup to see if that board gets the same issue
