I imagine it would be very difficult to downgrade your firmware if its already updated you may just have to wait for samsung to release new firmware with a fix or go through the same return process the reddit poster went through even though there would be no guarantee you would get a replacement with the older firmware.
https://linustechtips.com/topic/1479189-samsung-g8-oled/#findComment-15739328
My God, since when does monitors have firmwares?? And lol at this:
4 hours ago, Eiziv said:
I agree. I just talked to Samsung and they seem clueless. He was like "You have to have a AMD graphicscard for the best latency"
For real, the fuck is wrong with Scamsung? Been waiting for QD-OLED 16:9 but all they do is releasing ultrawide/curved monitors and nothing else.
Can't you return it? For that shitty service I would return it and get something else.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
https://linustechtips.com/topic/1479189-samsung-g8-oled/#findComment-15739613
  • 1 month later...
1 hour ago, Fifagi said:
What Post ?
I've a Oled G8 and i want know if i can lower the input lag
Thanks
For some reason the guy deleted the entire thread. Try looking up Input lag reduce Samsung  g8 Oled
https://linustechtips.com/topic/1479189-samsung-g8-oled/#findComment-15816853
