PC low power toggle?
By
JComputer
in Troubleshooting
in Troubleshooting
Solved by DoctorNick,
Specs.
Edit: I see you've listed specs in profile.
Also did you overclock your PC without enabling power saving features in bios? If you tweaked your CPU, then you'll need to manually enable it. Also just set windows power plan to balanced. My PC for example uses ~20w idle
anothertealtiger ·
Mumintroll ·
Posted in Programs, Apps and Websites3 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3 -
IAmAndre ·
4
play_circle_filled
Latest From ShortCircuit:
