Problem with type c charging
Go to solution Solved by Levent,
Issue might be the your laptop after all. I found this on Dell forums and it seems you got nobody other than Dell to blame.
bought a 200W GaN USB C Wall Charger with a SooPii 100W USB C to USB C Cable to charge my XPS 15 7950 using USB C (Thunderbolt 3). but it only "holds" the battery, as it sees it as a 65W charger. I suspect the problem to be the cable, even tho its supposed to be able to charge up to 100W, please help.
https://www.amazon.ca/gp/product/B0B53BFFGY/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
https://www.amazon.ca/gp/product/B09V82LKK3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
https://linustechtips.com/topic/1478300-problem-with-type-c-charging/
2 minutes ago, BuildAddict said:
true, but when i plug a XPS 15 9570 type C charger, it charges at 90W...
That's Dell's charger. From that thread, it seems they are limited to 65 W from anything not Dell.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
