Hot Spot Difference
Go to solution Solved by Levent,
8c difference between core temperature and hotspot is probably best I have heard of to date. Mine is around 13-15c higher than core temperature. Everything sound great here, don't touch it.
Hello,
I recently got an RTX3080ti (MSI Gaming X Trio) and I finished replacing the thermal pads (Gelid GP-Ultimate 15W) and repasting (Thermal Grizzly Kryonaut). I have much better thermals now where my memory is much cooler as well as my processor.  Ran Furmark and it leveled out at 62C on the processor with a hot spot of 70C. I was wondering if this is a normal difference or if I maybe didn't paste correctly and need to crack it back open and re-paste again.
Thank you in advance!
https://linustechtips.com/topic/1478284-hot-spot-difference/
https://linustechtips.com/topic/1478284-hot-spot-difference/#findComment-15730781
