I am trying to upgrade from an rtx 2070 to a 6800xt I got from a friend. The card is only a month old and worked fine in his PC ( that I built for him). When i put the card in my PC I keep getting a d6 code. I put my 2070 back in and it boots up fine. The lights come on and the fans spin on the 6800xt but no video output. I already flashed the bios on my mobo, Uninstalled all nvidia drivers using ddu in safe mode. I have taken the 6800xt out countless times now to make sure it was seated properly. I can't figure it out for the life of me, hoping someone on here can help. Info on my setup.
011 mini case
Cooler master 850w sfx psu
X570 meg ace
5800x cpu
Gskill trident neo ram 32gb
https://linustechtips.com/topic/1477664-need-help-with-6800xt/
011 mini case
X570 meg ace
5800x cpu
Q-Code D6, No Output Defected
Make sure all the PCI-E 8-pin power connectors are connected -- they are NOT optional.
Depending on the model of "6800XT" you have, it could be 2x 8-pin, or 3x 8-pin connections.
What version motherboard BIOS did you flash to?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1477664-need-help-with-6800xt/#findComment-15726624
Try a different PCI-E slot.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1477664-need-help-with-6800xt/#findComment-15726795
