Posted December 30, 2022 Hi all, I have 25 thousand Argentine pesos, and I am looking for the best case for my low budget. I made a poll of the cases I found within my budget. The difficulty I found when choosing is that I have a 200 mm PSU (supernova g2 1000w) But if you guys have any other alternative, I am open to receive help. Thank you very much to all of you. Best regards. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 30, 2022 Best air flow: https://www.amazon.com/Yoidesu-Vertical-Overclocking-Aluminum-Water-Cooled/dp/B086X671KL (on a serious note, it gathers dust a lot, but keeps things cool) NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2022 Author Any help? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2022 The cases you listed are decent mesh cases, but the power supply you have is kind of long without removing the drive cages. Usually the cheaper cases have drive cage that are not removable. It should be easy enough to drill out the rivets to remove the cage if necessary. I looked up the P300a and it said max length PSU was 200mm. You also have to factor in the cables sticking out forward before bending away. The Cooler Master TD300 mesh drive cage can be move closer to the front. You can pick a decent mesh case that is more visually pleasing to you and if the cooler fits. I like the Fractal Meshify C, but not sure what that would cost with your buying options. CPU: AMD Ryzen 9 3950X Motherboard: MSI X570 Gaming Edge Wifi Case: Deepcool Maxtrexx 70 GPU: RTX 3090 RAM: Corsair Vengeance LPX 3x16GB 3200 MHz PSU: Super Flower 850W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2022 Author 2 minutes ago, alyen said: . I like the Fractal Meshify C, but not sure what that would cost with your buying options. The first two links are online stores in my country, the second link is a hardware search engine. My budget is 25 thousand Argentinean pesos. If you help me find a better option, very grateful in advance. Best regards. https://listado.mercadolibre.com.ar/computacion/componentes-pc/gabinetes-pc-soportes/gabinetes/gabinete_PriceRange_0-25000_NoIndex_True#applied_filter_id%3Dprice%26applied_filter_name%3DPrecio%26applied_filter_order%3D5%26applied_value_id%3D*-25000%26applied_value_name%3Dnull*-null25000%26applied_value_order%3D4%26applied_value_results%3DUNKNOWN_RESULTS%26is_custom%3Dtrue https://compragamer.com/?seccion=3&cate=7&sort=lower_price https://www.hardgamers.com.ar/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2022 I have a Deep Cool Matrexx 55 Mesh and have to say I really like this case for the simplistic look. It might even look good lying down on its side on a shelf but is probably too long for most shelves. The drive cage is secured with rivits, but I removed it for my build. This case would have been a great budget build if it had a removable drive cage with some mounting points for a fan on the bottom and if the PSU shroud didn't do go so far to the front. https://compragamer.com/producto/Gabinete_Deepcool_MATREXX_55_MESH_9967 CPU: AMD Ryzen 9 3950X Motherboard: MSI X570 Gaming Edge Wifi Case: Deepcool Maxtrexx 70 GPU: RTX 3090 RAM: Corsair Vengeance LPX 3x16GB 3200 MHz PSU: Super Flower 850W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2022 Author 2 minutes ago, alyen said: I have a Deep Cool Matrexx 55 Mesh and have to say I really like this case for the simplistic look. It might even look good lying down on its side on a shelf but is probably too long for most shelves. The drive cage is secured with rivits, but I removed it for my build. This case would have been a great budget build if it had a removable drive cage with some mounting points for a fan on the bottom and if the PSU shroud didn't do go so far to the front. https://compragamer.com/producto/Gabinete_Deepcool_MATREXX_55_MESH_9967 Power Supply Type ATX PS2 (Length less than 170mm) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
