Budget (including currency): 10500 RON - 2260 dollars
Country: Romania
Games, programs or workloads that it will be used for: Gaming (Half Life: Alyx VR, Bonelabs, Rick and Morty: Virtual Rickality, Fallout 4 VR, Resident Evil 7, Scrap Mechanic, Slime Rancher 1 and 2, GTA 5, Rocket League, Cities Skylines, Euro Truck Simulator 2, CS:GO, Interent Cafe Simulator 1 and 2), Editing (Adobe Premier Pro, Lightroom and Photoshop, Corel Draw 2), Game Creation (Unreal Engine, Unity)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have an existing part list: https://ro.pcpartpicker.com/list/f9dQ2m, peripherals are not needed, I'm gonna buy in March 2023.
https://linustechtips.com/topic/1476997-help-with-a-pc/
57 minutes ago, bluemoon99 said:
Also, I really want the new 13th gen intel. If it's not good, feel free to say.
The 13th gen intel CPU is fine, but expect to have no upgrade path. When you want to upgrade your setup in few years you will have to get new motherboard and CPU maybe even new ram. The parts seems all right, but Why spend so much on the motherboard. Maybe get a cheaper motherboard and bump it up to rtx 3070 if that is an option. Or you can get a used one. Also there is Rx 6*** series they offer performance at and above 3070 level for lower prices.
https://linustechtips.com/topic/1476997-help-with-a-pc/#findComment-15722057
