Hello, i had my pc turned on for about half a day and after turning everything off and sleep. After the next day my pc wont turn on anymore. All i did was do my homework and play video games while recording. I didnt smell any burnt stuff or experienced crashes. It just suddely died. I have a very bad psu, its a Aerocool Vx500 green labeled and i really wanna know if my psu took some parts with it or it died peacefully.
(Sorry im not good at english)
https://linustechtips.com/topic/1476526-my-psu-died-help/
I mean there are only a few ways you would be able to tell if other components were damaged when the pc died is to have a look at them and see if you can see any sort of burn marks, next would be to check for shorts on the components if you have the correct equipment to check for that sort of stuff or you could get another gpu ( a good quality one) and see if everything boots correctly and everything is detected
https://linustechtips.com/topic/1476526-my-psu-died-help/#findComment-15719070
Do you have another PC that you can swap out components with?
If you have access to another PC that has the same cpu and ram compatibility then you can narrow down the list of culprits / dead components.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1476526-my-psu-died-help/#findComment-15719078
Thank you for the responds. Sadly i dont have another Pc to test parts out and any equiptment to check for shorts in my components, but i dont see any burn marks or anything. So is it possible that i got lucky and it died peacefully or it shorted out my components. Also i think that my PSU died from overheating or that it gave out after a long use.
I forgot to say that my psu is plugged into a AVR
(please correct me if im wrong because im not a expert at computers and stuff sorry)
https://linustechtips.com/topic/1476526-my-psu-died-help/#findComment-15720387
Nobody here can tell you if it killed any other parts. That is something only you can tell us.
https://linustechtips.com/topic/1476526-my-psu-died-help/#findComment-15721620
My unlce gave me an old optiplex 390 desktop pc but he told me that the cpu socket pins are broken.
Can i test some parts there? I checked the inside and theres no ram, no hard drive but i saw a psu and a cpu in there. Will it work ?
https://linustechtips.com/topic/1476526-my-psu-died-help/#findComment-15725973
