I have far more experience with the wands than the index controllers, but iirc the Index controllers aren't great if you have particularly large hands.
It's possible you're perhaps gripping them a bit too hard, which is an issue I definitely encounter when using a flight stick for example.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
