Threadripper 1950x cause a bottle neck with a 2080 ti
33 minutes ago, Deathstrike19781 said:for 1080p Gta , seige , overwatch , F1 22 what would you recommend and if i upgraded to 1440p would the 1080 be worth the buy ? im suprised the 1080 bottlenecks it as they where being bundled together and sold
2080 Ti. Is the fastest of the options presented, again unless you're shooting for high refresh and/or refuse to use v-sync, should be a non-issue, and it'll last longer before needing to be replaced. Also the most powerful out of those options if you want to do any non-gaming, it's a rather beefy CUDA card with a fat chunk of VRAM.
If you're worried about power then just get the 3060 12GB. Not the 8GB model, it's shit as explained by the other guys a bit above.
5 minutes ago, Deathstrike19781 said:I think it can survive a week or two and like i said if someone can give me a point in the right direction to one ill get it its just ominous looking at the list of safe power supplys
Check EVGA's B-Stock (refurbished, certified to function like new with at most cosmetic damage, my stuff has always looked crisp tho, and 1 year warranty vs the standard 3-5) section tomorrow:https://www.evga.com/products/ProductList.aspx?type=8&family=Power+Supplies, they usually put B-Stock stuff on sale on Wednesdays. The G/P/T[number] series are at worst solid, at best very good. I think the GA series is decent as well, but I'm not up to snuff on them so you'd want to look for a review from TomsHardware or Aris that breaks down how the PSU functions and any glaring issues with them.
