Nintendo Switch Power Supply
Solved by Alex Atkin UK,
58 minutes ago, Greenbell7 said:Is it ok to use the power supply that comes with the Nintendo Switch to charge laptops? I want to make sure that I'm not damaging my Macbook's battery by doing so.
I'd not recommend it, in fact I wont use anything other than the official Macbook charger as there have been reports of the charge chip dying even when using chargers that should have been compatible.
The Switch PSU especially not recommended as its slightly none-standard which is why unofficial Switch chargers were also reported to damage the Switch, in fact as I recall there were even some unofficial docks which caused issues using the official charger.
