DRAM Q led
N37F
I just built a pc
I5 13600KF
Asus prime z790-a
No gpu
I am waiting for the rx 7900 to drop
When i turn the pc on the yellow light turn on for 5 seconds then off
Then the white light(VGA) turns on which is normal cuz i don't have a gpu nor integrated graphics so i cant boot the computer
All the fans spin and the rgb works
But I just want to know if my ram is fine or not so i can replace it before its too late
1 hour ago, N37F said:
I just built a pc
I5 13600KF
Asus prime z790-a
No gpu
7900 afaik has no iGP, so it won’t post without some sort of video card. Doesn’t have to be a good one.  If you don’t have anything just lying around Maybe grab some $20 POS off  eBay or something, then swap it out once you get a card.  You can at least do some setup that way and do a bit of web browsing.  Thing might even be worth keeping just for diagnosis stuff. Basically anything that has a video out you can hook your monitor to is pcie, and that runs at least directx9 should be fine.
