I’m looking to get some new subs for my truck I got 1 12 inch now and I want 2 will this setup I’m looking at work well?
2 12 inch jvc drvn subs 4 oham
600w alpine mrp-m650 amp
used for 100$ for all will that work the amp seems a little low wattage for 2 12 inch subs am I wrong?
My Gaming Rig - Ryzen 7 3700X (4.4ghz all cores @ 1.3v) - Asus Strix GTX 1080 TI - 32gb Corsair Vengeance LPX 3200mhz - Asus TUF Gaming X570-Plus (Wifi) - Evga Supernova 750 GT - Deepcool Castle 360ex - 1Tb WD Blue NVME SSD (Boot) - NZXT H9 Flow
https://linustechtips.com/topic/1473359-car-audio-help/
The subs starts at 82 dB efficiency. Even if your amp true power is 150watt that is already should be pretty plentiful to reach 85 dB for in-car music session.
HOWEVER if you want to blast the entire neighborhood, I would consider having second amp to run in dual mono.
https://linustechtips.com/topic/1473359-car-audio-help/#findComment-15703830
The NUMBER for amp output is kind of a max figure it can take on.
If the woofer puts out 82dB at 1M and 1W, then if you're 2M away (6.6ft) it'd take 4W to hit 82dB output at the listening position. If your goal is 92W sustained (enough to cause permanent hearing damage) you'd need 40W of amplification. 102 peaks would need 400W but it's unlikely you'd even want to play THAT loud.
If you are worried about amplification, I'd opt for more efficient woofers (e.g. 85dB/W/M) if possible since that would cut the amplification needed in half.
Also be aware that just because you have TWO woofers, doesn't mean you need 2x the amplification to provide sound to the same space. Total output at the same level of wattage should be very close to constant. If you're doing EQ to handle nulls, you'd actually come out a bit ahead since less EQ is needed.
Relationship between decibel level and intensity
One thing to keep in mind, doing bass in a small area is hard. nulls are going to be an issue. You should probably read an article or two on integrating subwoofers into the set up.
5900XT (16C/32T) | 64 GB DDR4 RAM | RTX 5070
1.5TB Optane P4800X | 16TB nvme SSD NAS w/ 10Gbe & 96GB DDR5 RAM caching
LG C4 + QN90A | Sony AZ7000ES | Polk R200+R100, ELAC OW4.2, SVS PB12-NSD + 3x SB1000 | HD800
https://linustechtips.com/topic/1473359-car-audio-help/#findComment-15709522
