My pc case doesn't have mesh on the front or even any vents near the front of the case. It only has two places for fans at the top and one place at the rear. All of them are 120mm. What would be the best airflow configuration for that particular instance? Which ones should be intake and which should be exhaust?
I have ryzen 5 5600 with stock cooler that gets pretty hot so any suggestions would be helpful.
Thanks in advance :)
https://linustechtips.com/topic/1471754-pc-case-fans-positioning/
Pictures would help... or time to break out the MS Paint skills
Also, I wonder if your PSU can serve as an exhaust too.
The rule of thumb is try have more intake than exhaust. You can also install aftermarket filter for intake fans but might not worth the trouble.
I assume the PSU is at the bottom and can be used as an exhaust.
I just bought three deepcool fans that I will position the same way as they are on the picture. Also, my PSU fan is actually looking downwards because there is a filter that I suppose is there for that reason.
Anyway, thank you so much for helping me out
well i dunno if i agree with this picture... you defo need front intakes as well...
also is your psu on top or bottom?  i suppose bottom,  but its not quite clear to me as you said looking downwards...
this is my pc, no front mesh , but a side "mesh" (actually its honeycomb)
temps are actually quite low... actually it's rather cold when not under load... (otherwise like 50-70c)
also note my psu is on top actually acting as a second exhaust
-Scott Manley, 2021
If your PSU is on the case floor, it is drawing air from below the case and exhausting it out the rear.
Few cases do not have front intake fans. What is your case?
My case is MS Fighter S300.
And yes, my PSU draws air from below, that is what I wanted to say 😄
My case doesn't even have any side mesh and that is making it problematic.
While playing warzone for example my ryzen 5 5600 goes up to 83c and the case becomes hot like an oven (I am currently using stock cooler)
no offense but this seems like one of the worst case designs ever, also isnt it already like in the picture posted,  minus the psu?
in the picture the psu at least helps slightly with air circulation,  in your case its completely isolated and cant help with air circulation at all. i don't really see a way to configure this differently,  you bought a hotbox and that's what you got. theoretically higher fan speeds should help, but that can only do so much.
-Scott Manley, 2021
Okay, I will try with fans and if that doesn't help... well I guess I'll have to change the case
Thanks for the help guys!
If you have a discreet GPU you should set the two top fans as exhaust. Otherwise there will be no clear airflow path as the GPU is designed to exhaust upward.
You might try having the rear as exhaust as well. Not sure how well that will work, but it's worth a try. The alternative is making it an intake. Easy enough to experiment with that fan.
