Radiator and dust filter?
Solved by RollinLower,
2 minutes ago, Christrix said:Have an Arctic Liquid Freezer 2 and with a carbide 275r none airflow. Radiator is top mounted and just wondering if its okay to leave the dust filter on fans are set up for intake. Thanks!
ofcourse that is okay. it will be a bit more restrictive, but if it is setup as intake you definitely want some filtering going on.
6
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking15 -
apoyusiken ·
Posted in PC Gaming9
