Just want some thoughts and feedback on these parts i have for a CPU water cooling Loop in my 900d.
XSPC RayStorm CPU Waterblock for Intel
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18563
Alphacool NexXxoS XT45 Full Copper 480mm
http://www.pccasegear.com/index.php?main_page=product_info&products_id=24247
4x Silverstone AP123 120mm Air Penetrator Fan
http://www.pccasegear.com/index.php?main_page=product_info&products_id=23431
Phobya DC12-400 12V Pump
http://www.pccasegear.com/index.php?main_page=product_info&products_id=23982
PrimoChill PrimoFlex Advanced LRT Tubing UV Blue 3/8ID 5/8OD 3m
http://www.pccasegear.com/index.php?main_page=product_info&products_id=22503
Alphacool 16/10 Compression Fitting 90 Degree G1/4 Chrome
http://www.pccasegear.com/index.php?main_page=product_info&products_id=24264
Alphacool 16/10 Compression Fitting G1/4 Chrome
http://www.pccasegear.com/index.php?main_page=product_info&products_id=24266
Liquid Fusion 250 mm Reservoir
http://www.frozenqshop.com/liquid-fusion-250-mm-reservoir/
https://linustechtips.com/topic/147134-900d-water-cooling/
You want to have different fans, there are better out there for the same price, as example eloops.
Have you thought about the coolant yet?
My Rig "Jenova" Ryzen 7 3900X with EK Supremacy Elite, RTX3090 with EK Fullcover Acetal + Nickel & EK Backplate, Corsair AX1200i (sleeved), ASUS X570-E, 4x 8gb Corsair Vengeance Pro RGB 3800MHz 16CL, 500gb Samsung 980 Pro, Raijintek Paean
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965075
I'm gonna go right ahead and say it, the biggest advantage in spending all the dough on a custom loop is to WC dem GPUs, it removes so much noise from the system and halves temps.
Might wanna wait a bit and splurge on GPU blocks and an extra rad.
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965081
Oh, just noticed you have a 900D, meaning...MORE RADS, MORE WBs XAXAXAXA
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965095
No not yet I'm still looking at coolant. Any recommendations?
At this point I don't have a need for gpu cooling as I'll be mainly using the CPU for work so I want that as stable and cool at all times.
However I will be cooling the gpu in the future after I have this rig setup and put a bit more money to the side.
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965097
If you dont want to have a general maintenance of your loop every year or so, I'd recommend distilled water + additives (biocide + anti-corrosive).
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965216
^^^^ As was mentioned..the huge plus to your Cutom Loop is the GPU Cooling for sure.....like night n day!!!
I went with Fesser 1 Clear Coolant...no additives required...you're going to be "servicing" your Loop every year minimum regardless....
Here's a couple of pics of my 900D...cooling 3930K and 2 780Ti's...everything OC'd...not heavily...as in 4.8 Ghz CPU and 1240 Mhx GPU's ;)
Went with 2 x 360 Rads and will be adding another 240mm.....sure you can fit 480mm Rads, but more rrom to work with 360mm's ;)
I have since tucked away the PCI-E cables.....nice clear spot now for my 240 Rad ;)
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
https://linustechtips.com/topic/147134-900d-water-cooling/#findComment-1965630
