First time overclocking Ram please help
10 minutes ago, Ebony Falcon said:where do I start ?
Set 1.45V (1.5-1.6V if you have active cooling) for the DRAM voltage, set 1.4V VCCSA, make sure to set Gear 1, and loosen out the primaries a bit. Start increasing the frequency until it stops being able to POST, then start lowering the frequency until you're able to quick memory stress tests (I like Y Cruncher 2.5B since it only takes a minute and spits out a performance result, but you can pick something else). Also, disable the E cores and setup a static overclock, it doesn't need to be anything crazy high or anything but you will be checking to make sure there aren't any performance regressions so having a locked core clock helps make sure that it's changing (locking it at max turbo isn't a bad idea). Disabling the E cores is because they can cause issues with some memory stress tests.
Once you have the frequency dialed in as likely to be stable, start lowering the primary timings one by one until you fail to POST, then start walking them back up till you can pass memory stress tests. Primary timings don't really make that much of a performance difference, but on Intel they do have some relation to other, more important timings so you want to get them dialed in first. tRAS you can just punch in 28 (the lowest that timing goes IIRC on the DDR4 Raptor Lake IMC, though it might be different from previous Intel memory controllers or the DDR5 Raptor Lake controller), 2T command rate will be a must, and tRCDWR can just be set to 8, meaning the only three primary timings you need to worry about configuring are tCL, tRCDRD, and tRP. Try to get those dialed in, lowering them till they won't boot, then raising them till they pass stress tests. Once those are dialed in, move on to tRFC and tREFI. Set tREFI to something reasonably high, 66666 is almost guaranteed to not have issues, 111111 is slightly more likely (my kit of DDR5 will error instantly with a tREFI this high) but still incredibly rare to cause issues, and 262000 (maxed out) will give the best performance and probably be OK, it can sometimes run into hard to diagnose errors so it's not necessarily a good idea to run this, even if you can boot and run stress tests short term with it. tRFC doesn't really matter so much once tREFI is as high as it is, so I'd just set it to 300 and call it a day. It can probably go lower but it's not worth the hassle of tuning it lower since the performance difference is so low. After those are set, set the tRRD timings and tFAW. tFAW should go to 16, tRRD_S should go to 4, and tRRD_L will likely go to 4, but if there's stress test instability set this to 7 (4 rarely causes issues, but it technically can, while 7 almost certainly won't). If you want to tune no more timings, have those tuned, those are what make the biggest performance difference. No matter what though, I'd do an overnight stress test on those just so you don't have to think about them when tuning the tertiary timings.
