Fitting RTX 4090 Case
Go to solution Solved by SpookyCitrus,
7 minutes ago, Mighti said:
I've seen a video from Linus now. He showed the Corsair 4000D Airflow Mid Tower. It's like 110 Euro. Do you think that it will fit? 🙂
What 4090 are you getting? They are different lengths and the 4000D Airflow will only fit certain lengths so, in order to know if the case will work we need to know what 4090 you want or you will need to pick one that will fit that case specifically. Again you can use PCPartpicker to filter which 4090s will work in that specific case....
Hello,
I've been looking around for a case for a 4090. I've searched around and found several cases. But some of them are 200 Euro and more.
Do u know some cheap cases for a 4090. It should also fit a Dark Rock 4 Pro, an normal sice PSU and a ATX MB.
I'm starting to get confused with all the clearence issues with this card and just need a normal case. No RGB is needes a glass side windows would be nice. 🙂
Edit.: I thought about the Fractal Design Meshify C, do you think it is too small?
Thank you 🙂
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/
What model of 4090 do you have?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679699
Just now, Mighti said:
I don't have bought one now. First of all I want to get all parts, check prices and if I find a good deal on one I'll take it. 🙂
Well. They're different sizes, so decide on a 4090 you want, put that into a PCPartPicker list and then look at cases, should auto-filter to ones where it should fit. Decide on a case you want, double check the manufacturer page to confirm the card will fit, and if so then buy it.
Mouse: EVGA X17
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679706
So there is no case that would fit every 4090? 😕
I just don't want to worry about the size of everything. Just one simple case with good airflow and I would be happy 🙂
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679707
Then just get a full tower. The cheapest ones are like $140ish USD I believe, I use a 750D Airflow that was around that. If you want a modern case, you're looking at that $200 price point you mentioned not liking. I would recommend just getting a case that does what you want even if it's expensive, as cases will last through practically infinite rebuilds, worth getting a good one.
Mouse: EVGA X17
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679711
The Phanteks P500A is a Mid ATX that should fit any of the 4090s as well as a DRP4 with included RGB fans and plenty of room for whatever you wanna put in it for around $150 to $180. Even then really any Full ATX case should fit them as well, it's just a matter of price, $150 to $200 is going to be the average for a Full ATX case. IMO if you're getting a 4090 a $200ish case shouldn't be that big of a deal. And again as others have suggested putting your build into PCPartpicker is going to be the best way to find compatible parts if you don't already have the knowledge of what will work. It literally does it all for you and will even compare prices.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679719
This is largely what pushed me to the Define 7 XL. It was definitely at/above that $200 price point, though.
Really, I feel like if you're buying a 4090, a pricier case shouldn't be a major concern.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679727
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679729
You are right, but if there's a cheaper way, why don't go for it? 🙂
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679733
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679739
1 minute ago, SpookyCitrus said:
What 4090 are you getting? They are different lengths and the 4000D Airflow will only fit certain lengths so, in order to know if the case will work we need to know what 4090 you want or you will need to pick on that will fit that case specifically. Again you can use PCPartpicker to filter which 4090s will work in that specific case....
Ok 🙂
so as far as I can see there is like no case around for under 200 Euro that will fit.. let's say the bigges 4090.
But anyway, I'll try my luck somewhere else. Thank you. 🙂
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679745
I'm with you on that one, but I also believe that if you can only fit a GPU in your case by either getting a bigger case or extensively modifying your current case, why not just buy the bigger case?
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679750
2 minutes ago, Mighti said:
Ok 🙂
You don't need to try your luck elsewhere, literally just put your parts that you want into a build list on PCPartpicker.com and it will list everything compatible with eachother. It's very easy and simple to do. Otherwise you just simply check the length on the card to what the case listing shows as it's compatible GPU length. It's very hard to recommend cases as a big thing with them is aesthetics, so just finding a generic case that fits every 4090 should be fairly simple whose to say if you'll even like it? It's easier for you to use PCPartpicker and have a list of all the cases that will work with your parts and you get to pick the one you want.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679752
I don't have a case to modify right now. My actual case barely fits a gtx 1070. I just wanted to know a "cheap" case that will fit bigger cards. Just some recommandations. As I said, if I just can save money, why not do it.. If the only way I can fit one is to buy a 200 Euro + case, ok I'll do it. I just thought that there are some cheaper options. 🙂
Well I  don't know if it accounts the few inches that the cables need extra space.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679767
I built a testbench out of Lego once and ran my PC off of that. Your best option is probably looking for a used ATX full tower case, if you don't want to spend the money on a new one.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679770
Well I think I've found the solution myself. Just looked for the biggest 4090 and the case. https://pcpartpicker.com/list/BBqhd9
As far as I can see there shouldn't be a problem?
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679777
Cool, there you go. Just remember to double check the case with the exact card you end up going for as another card could be incompatible with case due to other physical dimensions. It's always best to be safe than sorry.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679792
Yes of corse. 🙂
I was just wondering, are the few inches for the cables already included or do I have to account the cable length extra for this? 🙂
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679796
5 minutes ago, Mighti said:
Yes of corse. 🙂
The cable length for the power cables to the GPU? It should be, you can always double check it by checking the width/depth of the case vs the width/depth of the card.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679798
No, I worry about the clearance between the glass front and the Powe connectors of the GPU. Most of the time it's hard to find the max with of the case from the MB tray on.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679807
That's what I asked... If PCPartpicker says it will fit, it should. It's not too hard to figure in the depth of the case minus the motherboard, motherboard standoffs are what only 6.4mm tall, motherboard on top is going to be an extra 6 or 7mm to the PCIE slot. So 14mm ish from standoff to PCIE slot where the GPU goes, give or take. Width of the card is 162.8mm for the Aorus 4090, plus on that Aorus card the power connector is receded into the heatsink so you actually have less cable sticking out the side. The width of the case is 230mm, usually the distance from side panel to motherboard tray is anywhere between 20 to 25mm. So if we subtract the motherboard thickness and distance between the tray and side panel from the overall width you get 191mm of clearance from PCIE slot to glass panel, with the card being 162.8mm wide that leaves 28.2mm(1.11 inches) of clearance or more due to the recessed power connector for the power cables to fit in. I honestly think it's plenty or room, if you're really worried you could also just buy a 90 degree power adapter. Honestly, I probably shouldn't have even done the math and just said it will fit but going off the rest of the post you'd probably ask for proof or an explanation, so I took the time to fully explain it. IMO I really think you're way overthinking this and making it more complicated than it needs to be.
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679823
https://pcpartpicker.com/b/bMk6Mp
Looks like plenty of room to me. You can look at completed builds on PCPP and compare the height of the FE to what ever card you end up getting.
@SpookyCitrusI found pictures 😉
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679836
Or yes, you could do that. 😞 I completely spaced looking for completed builds on PCPartpicker lol...
https://linustechtips.com/topic/1470925-fitting-rtx-4090-case/#findComment-15679838
  • 2 weeks later...
