Best wireless mouse?
Solved by Light-Yagami,
Well, I recently bought the Logitech G Pro X Superlight. Battery lasts 3 weeks with 3 hours of active use daily, it has the best sensor on the marker and it's the lightest mouse by far, weighing just under 60 grams. It comes in black and white. It's also one of the most expensive mice on the market while only offering two programmable buttons.
But for me, it's great. Feel like air and it's extremely smooth to use. It has a skipping distance of 1.2mm or sth..
Idk.. I used many good mice in the past like G403, Death Adder and Death Adder Elite from Razer, MX Master 2 and 3.. This is by far - and I mean - BY FAR the best mouse I have ever used. Highly recommended if you've got the cash
