Specs:
CPU: Intel Core i5 3570K @ 3.40GHz
RAM: 16.0GB Dual-Channel DDR3 @ 648MHz
Graphics Card: 2048MB GeForce GTX 660 Ti (nVidia)
Storage: 500GB Western Digital WDC WD5000AAKX-001CA0
Case: nVIDIA Limited Edition Case
Power Supply: 750W PSU (Unknown Brand)
Motherboard: ASRock Z77 Pro3
Cooler: Stock Cooler
Any ideas to make this build better? Things I wanna upgrade:
Power Supply: To a 1000W
Case: Mid-Tower Good case w/ a side window
Cooler: H100i?
Help me out <3
https://linustechtips.com/topic/14692-review-my-build/
Looks pretty good.
Why are you using 1333MHz memory? Also, overclock that CPU, but you may need to get a new cooler (the H100i is great).
Do not get a 1000W PSU, its not useful especially since your system will only draw about 400w at max load.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/14692-review-my-build/#findComment-163522
Right, you certainly do not need a 1000W Power Supply, or even the 750W you have now, however you do seriously need a good brand power supply. Even 450-550W will be enough for your system if it's a good power supply. If you want to be safe for overclocking or adding more components you can get a 650W one, from Corsair, Cooler Master...whatever, just PLEASE get a good brand&quality power supply.
As for the case I would recommend the windowed version of the Define R4. Since it's...amazing :P
And yes the H100i would be a good choice, then again so would the H110 or H220.
https://linustechtips.com/topic/14692-review-my-build/#findComment-163536
Some quick, straight to the point tips:
  • Depending on the purpose for your build, contemplate whether you will utilise 16gb of memory in the desired applications you'll use.
  • 750watts is more than enough power; calculate the wattage your build will use http://www.extreme.outervision.com/psucalculatorlite.jsp'>here and consider saving money on memory and spend extra on a branded power supply with lower wattage.
  • An H100i is a neat cooler, it can offer you great over-clocking performance.
  • First Upgrade: the above.
Good luck with your build.
https://linustechtips.com/topic/14692-review-my-build/#findComment-163578
Specs:
Cooler: H100i?
Help me out <3
For reference, a 750W PSU can run two GTX 680s /7970s. 1000W power supplies are extremely excessive for most people, settle for a 600-750W PSU.
I can recommend the H100i, the stock cooler won't allow for much overclocking.
Don't get 16GB of RAM unless you KNOW that you'll need it.
Case: http://ncix.com/products/?sku=81477&vpn=CC-9011029-WW&manufacture=Corsair
RAM: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233180
GPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121656
https://linustechtips.com/topic/14692-review-my-build/#findComment-168722
Don't go for a 1000W psu it's just overkill, upgrade your cooler. If you want a H100i, check the spacings in the roof of your case for the 120MM fans. If the fan mounts are 15mm apart the H100 should fit but be careful of the radiator fouling on the RAM and mosfet/VRM heatsinks. If you want to go air cooled check out the Noctua NH-D14 it's a beast and will keep up with a H100. Also if you have enough money to spend grab an SSD to get some extra performance in games and windows.
MY RIG:
WHITE BITFENIX SHINOBI WINDOW EDITION - AMD ATHLON X4 740 (SOCKET FM2) - GIGABYTE F2-A85XM-D3H - OCZ GOLD SERIES 4GB - NOCTUA NH-D14 - ATI RADEON 5850 2GB VAPOR-X - OCZ ZS-SERIES 550W PSU - WINDOWS 8 64BIT
https://linustechtips.com/topic/14692-review-my-build/#findComment-169642
