And Why?
(its ecc memory)
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
https://linustechtips.com/topic/146804-memory-speed-question/
dual channel 1600mhz
he doesn't says how much the timings impact performance.
hdd: WD green 3TB
mouse: corsair m60
Lenovo T550
Status: Offline.
Nas:
StatusOffline.
https://linustechtips.com/topic/146804-memory-speed-question/#findComment-1960445
I would go with Dual Channel 1066MHZ CL7. This is because you can overclock the RAM and make it faster than other RAM. Also dual channel will give a theoretical doubling of memory speed.
its for a server (no overclocking)
hdd: WD green 3TB
mouse: corsair m60
Lenovo T550
Status: Offline.
Nas:
StatusOffline.
https://linustechtips.com/topic/146804-memory-speed-question/#findComment-1960449
I would still go with the 1066MHZ CL7. Can't you get 1333MHZ?
there is 1333mhz with cl9
hdd: WD green 3TB
mouse: corsair m60
Lenovo T550
Status: Offline.
Nas:
StatusOffline.
https://linustechtips.com/topic/146804-memory-speed-question/#findComment-1960488
