Will they run in dual channel?
Solved by Eigenvektor,
37 minutes ago, Ajay Singh said:(1) Will they will run in dual channel if paired together?
(2) Since I run my single channel RAM overclocked to 3200MHz without any issue, will I be able to run
this mixup overclocked at 3200MHz as well? Or will the only run at stock 3000MHz together.(3) Will dual channel at 3000MHz perform better than single channel at 3200MHz?
Thanks for any guidance.
1) Probably, but there is no guarantee. Only a short while ago we had a poster where one stick was single rank and the other dual rank and it would no longer run at full XMP speed.
2) You can try, but as always an overclock isn't guaranteed
3) Yes. Dual rank doubles throughput so 2x3000 is faster than 1x3200
