Hi everyone,
Need some help regarding extension cables mainly for the gpu. Back story-I have an MSI SUPRIMX RTX 3080 12GB & my PSU is a Phantex 1000W. Recently I bought an ezdiy-fab cable extensions kit. So on the end of the 6+2 PCIE Extention cable which goes to the gpu has a slight difference in on of the notch/square things. The end which attaches to the original PSU cable is OK. As the picture's show it's only in one connector that's the issue.
Now the problem is all the extension cables(6+2 PCIE) have the same issue. Is this something normal? Or is there some special extension cable for these GPU's? I did ask this from a local  PC repair shop & he said all his extention cables are the same too & said to give it a try as long as it can go in (no pun intended 😏)  Pls note that it's the mirror effect when you plug the cables to the GPU, before you say I have it confused😅IMG_20221109_203159.thumb.jpg.d1d1792e9deff42806117ddb926faeb5.jpgIMG_20221109_204004.thumb.jpg.6d8d4b1c702f9e359ae83e58615820e6.jpg
https://linustechtips.com/topic/1466618-extension-cable/
I’d get some cables from cable mod and not mess with extensions personally.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15647918
Never really looked and compared the ends on mine. I just get the cable and plug it in. Normally my psu's arent supported to get custom cables. Gonna look the same way most likely.
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15648199
to be 100% you need to probe the cables and a pin out. if its just an extension off the psu cables as long as the pins are the same should not matter if its a replacement cable for the psu then ya you would need to do some work...
Edited by thrasher_565
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15648476
I think it might be a UK thing🙄.The most frustrating part is Phanteks itself has cable extension kits but only have 2 PCIE 6+2 cables & I need 3 for this beast, but for the black/white theme I can't find any single 6+2 cables. So literally I have to buy 2 whole kits just so I can have 3 cables(6+2). The full kits that do have 3 PCIE 6+2 cables have the same issue with the notch. Modern day problems🙈😂
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15650630
i think like 99% of kits have 2 cables ones the have more cost more anyway...
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15650788
I just look if the cables match, so it will also work, because if this cable connects to your original PCIe cable then there should be no issues. If the extension cable plugs into the PSU itself then you need to check if it's the same like your original cable.
Intel NUC 13 | i3 1315U2x 8GB 3600/CL16
AMD 7950x3d | Sapphire 7800XT Nitro | 2x 16GB Corsair Vengeance 5600Mhz CL36 1R | MSI B650-P Pro Wifi | Custom Loop
AUNE X8 Magic DAC + SS3602
AUNE X7s PRO Class-A | Sennheiser HD58X
Schiit Rekkr ELAC BS243.3
https://linustechtips.com/topic/1466618-extension-cable/#findComment-15651658
