Watercooling loop help
Go to solution Solved by Zando_,
Sounds like you ran into morons. If you don't need the thermal headroom, more rad surface area is useless. Your temps seem fine, if you decide to stop undervolting and they get too toasty for your liking, then consider adding another radiator (I would put a 360mm in the front, and move the 240 you already have to the top, assuming your case can support that configuration).
1 hour ago, Lt Cmdr Ambrose said:
What is the delta between water temp and part temp usually?
You would need a coolant temp sensor to know that, I think it depends on individual setup. For my EVGA CLC 280 (an AIO) my CPU can hit the high 80s and coolant temp will sit at 36-39C, so less than half. I haven't been able to get my loop up and running properly yet (thus the AIO), when I do so I plan to have a coolant temp sensor for just that reason, want to see how the delta is.
Ok so I just finished my first custom loop build a little while back, and got roasted on R/Watercooling lol
I got this 6900 XT STRIX LC with a EK Waterblock already installed in a Razer Core X Chroma for 575$ on ebay. It was running in that config with a 120mm rad just fine, and the previous owner tossed the original cooler 😑
So I decided to build a tower with a 7700x and do a soft tubing loop with a 240mm rad. Being that I am a moron and didn't ask for help or think it through (forgot the drain port and temp sensor too🤦‍♂️), I thought  240 mm would be fine for this. 120 MM per part is what I was told for years, but everyone said my water temps are probably running too hot.
I played halo infinite and back 4 blood for about 2 hours straight and my gpu hit 46 C and cpu got up to 47C, which seems like it would be cool enough (I.E. Coolant temps should be lower than the 50C danger zone?). I keep my apartment at around 69F (nice)/ 20c, and both the gpu and CPU are undervolted.
Am I wrong on this? Do I need to add another radiator? What is the delta between water temp and part temp usually?
Thanks in advance for any help!
https://linustechtips.com/topic/1465013-watercooling-loop-help/
That was also before GPUs and CPUs started consuming over 300W individually.
I'd personally want another radiator, both of those are relatively hot components, but your temps do look fine enough since you're undervolted. I'd argue that undervolting (at least on a 6900 XT) doesn't really make sense though if you're going to be doing a custom loop, where the biggest advantage is extra thermal headroom to push clocks higher and higher.
https://linustechtips.com/topic/1465013-watercooling-loop-help/#findComment-15635650
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1465013-watercooling-loop-help/#findComment-15635762
I prefer 140mm fans. I do a 280 rad per device at minimum. Obviously, the case dictates most of that. I even do it with old hardware, 8700k and a 1080ti.
More is always better if you actually want better temps overall than on air and less noise. Or else its just for looks.
https://linustechtips.com/topic/1465013-watercooling-loop-help/#findComment-15637560
