I'll start off with my current specs that matter for this question and issue...
5950x
64gb ram "3600"
1tb 980 pro nvme
aio cooled
asus strix 3090ti LC
1k EVGA 80+ gold PSU
Issue is this:
   about a month ago, i updated my GPU driver on my "OLD 6900xt" GPU. when opening Edge browser, i noticed video glitches so bad it would flash off my screens for a second and come back on until i closed the browser out. i reinstalled and still to no glory had this issue. here is the issue i had with the 6900xt. via youtube.
If you look at the right screen you'll see edge flicker a little bit and then both my screens go dead for a second then come back..
well i seriously thought this was my gpu after self diagnosing and reinstalling everything. i returned this gpu and got the new current GPU.
A few weeks go by, zero issues at all nothing at all. not even a flicker. then it started happening again on the new WoW dragonflight pre-patch.
I noticed directx 12 was enabled by default. "after about 1hr of pondering why i took the 6900xt back and feeling guilty" i was like well that makes no sense it cant be that.
well, i changed from directx 12 to directx 11. IT FIXED IT!! no more issues in game, but still have issues with windows itself because of dx12.
If i screen record, these issues can't be seen. if i go live via twitch and these issues happen, it cant been seen but only by me.
i changed out DP cables to better ones, i made sure my PSU wasn't over or under volting. i checked my temps on everything. everything is acting perfect as long as the application is dx11 not dx12.
Motherboard, PSU or CPU is all i can think of as the possibility of a truly broken gpu not rendering dx12 isn't possible twice in a row. but im not 100% sure.
i even "upgraded" from win 10 to 11 and didnt fix the issue. maybe a full reinstall will fix it, even though ive truly tried that with the old GPU.
i need some more expert advice why dx12 games and apps are messing with my GPU like this.
EDIT: I've posted a video of WoW in dx12 causing the gpu glitch and showing the right screen on OBS not showing the issue
https://linustechtips.com/topic/1464635-dx12-issues/
