Hi, before I start asking anything, I'm sorry if I do or say something wrong, I'm new here and not a native English speaker. I'm Indonesian.
So I have a PC with this specification:
Motherboard: ASRock B550M Steel Legend
CPU: Ryzen 5 3600X
Graphic Card: MSi NVidia GeForce GTX 1650 Super Ventus XS OC
Power Supply: Corsair CV450 Power Supply
RAM: Kingston Hyper X Fury 3200Mhz (running with XMP) 8GBx2
Boot SSD: Kingston A2000 NVME SSD 500GB
Storage: two random laptop HDD (it's 500GB Kingston and 1TB Seagate)
Case: Cube Gaming AXEL (really similar to Cooler Masters NR200P)
no case fan and stock CPU cooler
Windows 11 Pro Dev Channel
I build this PC in October 2020 at around 1000USD or 14.000.000 IDR for video editing with Premiere Pro and Davinci Resolve, After Effect, Music Production, and Gaming. It's been running flawlessly, until it doesn't. Sometime around October 2021 my pc get some raindrops around the power supply plug area because of leaky roof, from then it's still booting fine, editing and gaming was completely fine. November 2021 my PC get raindrops again, this time while moving out. My just won't POST for some time, got it serviced and told it was the Motherboard, they repaired it (not replaced it). It's alive again for like 1 month and then suddenly it won't POST again. But if I leave it unplugged for like a day to a week it will POST and work normally. After that shenanigans I change my power supply with a new unit (same one, just a new unit). Got it working, but now my PC won't POST again. It's always slow spinning cpu cooler with RGB on and CPU and DRAM led on. Last week I tried to turn it on, same thing but with my graphics card fan not spinning. I don't know what's wrong or what is broken. Just today I tried to turn it on again. It turn on until I put my PIN to log in and then the CPU cooler just ramped up and my monitor go blank. Now the Graphics Card is kinda warm tho. Please help, I spend all my money on this thing :'
Edited by Yoga Wiranata
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/
AsRock B550M Steel Legend
Welcome! And we'll need more than just your motherboard unfortunately. CPU? RAM? PSU? GPU? etc.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625528
Remove all USB and sata devices. Turn off PSU, plugin a keyboard and update BIOS: https://www.asrock.com/mb/AMD/B550M Steel Legend/index.asp#BIOS
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625531
I've been considering this, but how do I update my motherboard BIOS if the thing won't POST?
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625538
Yes you need to get it to post first. Try what i said. After booting you can download the bios. Oh I forgot to mention. After turning off and unplugging sata and USB, remove the CMOS battery for at least 5 min. Then you should be able to turn on. Then download bios, put on USB drive, reboot and flash. Read the instructions on how to flash bios on support page for your motherboard https://www.asrock.com/support/BIOSIG.asp?cat=BIOS11
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625540
I just edited this topic, the issue is I can't get it to POST, but thanks for the suggestion. I will update my BIOS after my initial problem is resolved.
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625541
Just updated mypost, forgot to mention something, CMOS battery
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1463610-my-pc-wont-post-again/#findComment-15625542
