Hello everyone,
i thought a couple of time to upgrade my cooling solution. Actually i got an Cooler Master MasterLiquid ML240L RGB (bought 2018) and default NZXT Case Fans Front 120mm x3 and Back 140mm 1x in a NZXT H710 Case.
I ran as Motherbord a Aeros X570 Elite, an MSI 3070 TI, a 1TB WD Green and a Samsung 970 1TB SSD, with an AMD 7 5800x.
Allready notet, my CPU AIO as outtake on top was a misstake. I thought allready have 4 years on its back, maybe my AIO isnt that effective anymore ore should be changed out (rumors in my head telling me after 2 years you should swap the liquid but im not. As sidenote, my Temps dont go over 82 Degrees. on CPU and GPU.
Ik, i should be lucky about that. Could be a lot worse. Just thinking in near future (this year for sure) to upgrade. RGB for the AIO would be preferd, thinking about the Coolermaster Liquid ML240 v2. RGB wyt? RGB for case fans would be nice but unnecessary. Thx for help and sry for bad english ^^´
https://linustechtips.com/topic/1463347-thinking-about-upgrade-cpu-and-casecooling/
The liquid isn't meant to be replaced. Use it until you are not longer satisfied with the cooling.
