Help with budget build PC ( no GPU for now )
This is cheaper but performs basically the same. Could get 32gb of RAM but 16gb should be enough, so you could use the other money for a better GPU or something like that.
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (916.90RON @ PC Garage)
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler (366.34RON @ PC Garage)
Motherboard: Gigabyte B550M AORUS ELITE Micro ATX AM4 Motherboard (612.61RON @ PC Garage)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (331.89RON @ PC Garage)
Storage: Western Digital Black SN750 SE 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (528.12RON @ PC Garage)
Case: Corsair 4000D Airflow ATX Mid Tower Case (679.34RON @ PC Garage)
Power Supply: MSI MPG A850GF 850 W 80+ Gold Certified Fully Modular ATX Power Supply (728.96RON @ PC Garage)
Total: 4164.16RON
Generated by PCPartPicker 2022-10-24 20:18 EEST+0300
1 hour ago, A1600RM said:Also, the PC will be fitted with a 2070,2080 or a 30 series card later, since I'm still looking for good deals on a GPU.
I also recommend checking the AMD 6000 series. Usually are better value than Nvidia, especially if it's just for 1080p gaming.
Edit: Like said above, your system won't work without a GPU. If you want to use it before buying a GPU, get an Intel CPU without K or Ryzen with G (keep in mind that the 5600G is not a 5600 with iGPU, but a 5500 with iGPU which is slower and supports no PCIe 4.0)
