Question About Case Fans
Solved by Ryuikko,
Yea as long as they have the 4 mounting holes and the size that the case can fit i.e( don't try to put a 200mm fan in where a 120 should be) they are pretty universal
I'd reccommend lian lis sli uni fans if you aren't in the corsair scene already, mainly because I like the look of them and they are daisy chainable
Featured Topics
VinSen ·
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0
