(sorry for my bad englisch)
hello i have a pc with a ryzen 5 2600,gtx 1060 6gb, 16gb of ram and a 256 gb ssd.
my hard drive is strange tho its a toshiba 1tb hard drive and its acting weird.
when i got a faster internet connection i could never download at full speed (60 mbs) it always crashed down to 5 mbs (steam).
when installing a game on my ps5 it went perfectly fine.
about 2 months later and i tried installing resident evil 7 from steam and it went fine always downloading at 60 mbs.
so i tried downloading a diffrent game and it went fine again thenn a another game and then the crash happened.
wenn i try to install a game on epic games tho i always have a 50-60 mbs download speed.
is my hard drive slow, broken or is it just steam can some one please explain
(sorry that steam is in german)515924318_Screenshot2022-10-19133549.png.443ec5e84bd9fbeef0dc60195d69c9f1.png
https://linustechtips.com/topic/1462025-hard-drive/
If your internet speed is for example 20 MB/s but steam can only send you the game/files at 10 MB/s you will download at 10 MB/s,
that's why some games download faster, that's why the download speed is always different when it's a different thing.
Do you have enough space on disk for the games?
Are you doing anything else while installing games?
If you want to check the disk, there is a command for it, but it can take up to 5 hours to check the disk.
If I didn't answer all questions tell me, if you have any questions feel free to ask.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1462025-hard-drive/#findComment-15613645
if i download games the only thing i have open is steam
and my hard drive is always have empty cause i dont keep many games installed
the only thing i have running in the background is kaspersky antivirus but that is installed on my ssd
is there anyway i can check the hdd read/write speed without installing any third party software
https://linustechtips.com/topic/1462025-hard-drive/#findComment-15613685
As a system drive a regular hard drive is slow. And age just makes it worse.
You can check the drive health with Hard Disk Sentinel and CrystalDiskInfo.
And you can measure your Hard Drive read and write speeds with CrystalDiskMark and HDTune.
Also, if your Internet speed is 60Mbps (mega bits per second), translated to MBps that is 7.5 MBps or 7 MB/s ,a theoretical limit which would translate to ~5-6MBps.
Tl;dr   Du brauchst ein SSD, kumpel.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1462025-hard-drive/#findComment-15613686
There is one way to check the disks with cmd (no install needed),
chkdsk is the cmd command, but bare in mind that it can take hours to finish.
current PC:
https://linustechtips.com/topic/1462025-hard-drive/#findComment-15613697
my internet speed is 500 download and 50 upload which means i should download at 60 mb/s
but it doesnt on steam. on epic games its just fine 50-60 mb/s on steam its 10-20 mb/s
https://linustechtips.com/topic/1462025-hard-drive/#findComment-15613740
