Budget build help, please?
Solved by BK80,
3 minutes ago, SpookyCitrus said:I mean it's a little tough with this low of a budget. But these would work.
Not too sure on the case it's just the best looking deal for the price because it comes with all the fans already so you wont need to buy any extra.
I've used these TeamGroup drives a lot and they're super solid.
Hardest one to find the best deal on is PSU, I mean if you want to stay within budget you're looking at some cheaper units.
If you're saying they'll do the job i need, then that's all i need to know. Thank you so much Spooky Citrus
