Need help picking the right psu
Go to solution Solved by hypergod,
I'm more worried about the width lol there is metal psu brackets on the top and bonnet were the psu mounts verticaly
where do you live?
maybe RM550?
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Sorry I live in canada
Also I will be powering a
i5 4670k
Hdd
Ssd
Gtx 780ti
5 case fans
Fan controller
Cd drive
RM 550
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139053
its about 10 bucks above your budget but the fan doesnt spin up untill about it reaches 30% load, but its been proven that some models dont even spin up to 40% after 30 min or so
550w be enough for my system?
if you wont SLI in the future it will be more then enough,
I do plan on going sli in the near future was looking at the corsair tx750m is it a decent psu and not loud like a jet engine
My recommendation is the EVGA Supernova 750 G2 for $119.99 or $104.99 after MIR. http://www.ncix.com/detail/evga-supernova-750-g2-80-f0-94405-1070.htm?affiliateid=7474144
It's a excellent, high-end unit that is at an great price. It's among one of the best PSU on the market atm and offer a 10 year warranty (registration is required).
The XFX XTR 750w may be a good option if you can get it for less than the EVGA. It's a Seasonic G unit internally with full modularity, a better, quieter FDB fan than the Seasonic unit unit and the other XFX units in that wattage range.
Will that supernova fit in my case
This is your Corsair 540D case, correct? If so, then, yes. It should fit in it, as your case allows for PSU up to 200mm in length, and the 750G2 is a 180mm PSU.
Btw, don't mistake the Supernova 750w G2 for the EVGA NEX750G. They are two different units, where the NEX is an inferior unit.
That PSU conformed to the ATX standard (like the XFX you had), in which the width and height of it is 150mm x 86mm. The length of the PSU should be the only thing you need to worry about.
use this calculator to determine what size PSU you need and go from there. This is really accurate because I have a watt meter and it was only off by ~15 watts but it was close.
Also, to get the best efficiency it has to be 60% of the Full watts the PSU uses just so you know
so lets say you have a 650w PSU, the efficiency curve will be 390w that you should use, but you can use more than that if you want to but you will use more watts thus have lower efficiency
Edit: I would get a EVGA power supply if you can because those are one of the most reliable PSUs you can get and has a 10 year warranty
Computer and other things (My Phanteks Enthoo Elite build is done)
Main Computer
Processor: Intel Core i7 6850k @4.5GHz
Motherboard: Asus Rampage V ROG Edition 10
Heatsink: Custom Hardline
Memory: Corsaor Dominator 16GB (4GB x2) DDR4 3000MHz
Video Card: EVGA GTX 1080 FTW
Hard Drive: x2 OCZ ARC 100 240GB RAID 0 (Boot), Western Digital 4TB SSHD (Steam), x2 Adata 512GB (Steam)
Main GUI: Windows 10 Pro 64-bit
All That Extra Stuff
Monitor: x2 Dell U2414H
Keyboard: Ducky Shine 5 RGB (Cherry MX Blue)
Mouse: Logitech G502
Headset: AKG K553 Pro Studio Headphones
Speakers: Boston Accustics Home Media Theater 2.1 + Boston Accustics Soundbar
Microphone: Audio Technica AT-2035 w/ Focusrite Scarlett Solo
Sound: Creative Sound Blaster E5 DAC
Server
Case: Rosewill 4U Rackmount RSV-L4500
Processor: Intel Xeon E5-2670 V3 12C/24T
Motherboard: Asrock x99 Extreme 4
Ram: Kingston HyperX DDR4 2133 4x4GB
Video Card: Nvidia GT520
OS Drive: Kingston Hyperx 240GB SSD
Raid Card: LSI MegaRaid  9261-8i 8-port
Hard Drives: x7 HGST 4TB Nas
