Issue with mapped drives in different programs
Go to solution Solved by Kid.Lazer,
There are various ways to handle this, but the crux of the issue is that the drive was mapped in a user space, but not in a administrator space. (or vice versa)
The easiest fix is to enable linked connections in the registry, which will allow your administrator programs to access mapped drives that were created without administrator access.
Paste this into notepad, save as .reg file, then run the file to merge into your registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]
"EnableLinkedConnections"=dword:00000001
Hello!
So i recently reinstalled windows 10 on my main PC and i've run into a problem where if i try to choose my mapped network drive as a destination, for example if i want to use it for OBS it will not show up. It does however show up and works fine in windows file explorer for general usage (i can copy files to and from it just fine)
I remember having this issue before but i dont remember how i fixed it. Anyone got some clues on what to do?
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
1 hour ago, Mayaa said:
Hello!
Is it mapped as a network shared folder, or a shared drive?
Alright yeah that seems to be it, cheers.
Is there something i can do so i dont have to change the registry in the future?
Its a drive, but the fix above worked.
As far as I'm aware, the only other fix is to map the drive a second time as an administrator, but that's too cumbersome for me. I just keep that registry file backed up for future installs that may need it.
Primary Gaming Rig:
HTPC/Gaming Rig:
Alright, yeah thats what i was planning to do as well.
Thanks again.
