PC Not starting HELP!!!
Go to solution Solved by qwertywarrior,
odd
i guess some how ur mobo got fried sine a different PSU didnt fix it
So there was a huge thunderstorm last night and My PC was completly turned off and unplugged from the wall...My modem got fried which i replaced today and the lan cable was connected to my pc too...I cant turn on my PC now...The led on the Motherboard doesnt light up....I tried with diffrent PSU ...These are the specs ..My ps3 was connected to ethernet too It also got fried :\ But I need to fix my PC first...So please help me
Specs:
AMD FX6100
Asus m5a78l-m lx v2
4gb DDR3 1333mhz Ram
Nvidia GTX650Ti
Corsair TX650
Seagate 1TB HDD
Please help!
https://linustechtips.com/topic/145832-pc-not-starting-help/
first thing you need to do is get better electrical safety devices, since nothing would get damaged if you had a good fuse box and surge protection, also when plugging out make sure to remove the cable from the socket and not just have it laying there, since it can jump quite far
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/145832-pc-not-starting-help/#findComment-1947248
So getting a new mobo will fix right?
We can't say that it will. Call a mate and ask if you can test your GPU in his rig, or if you have it in your town, go to the local pc shop/workshop and ask if they can test it for you.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/145832-pc-not-starting-help/#findComment-1947290
