I am current rebuilding my first ever custom PC and I'm having trouble finding the new parts to replace the old. My first build had an I7-7700 16 gig Avexir Raiden series Ram and a Galax HOF 1080. It took me almost 2 years and an ungodly amount of overtime to build but it was worth it. She still works beautifully today but I'd like to update her to current spec. I can't find a HOF 3080 anywhere and finding any Avexir Raiden series ddr4 is like finding a golden needle in a haystack. If anyone has a hookup on either of these parts id be eternally grateful for the info.
https://linustechtips.com/topic/1457429-help/
Also, that i3 CPU is outdated for modern gaming and it would bottleneck a 3080 by a lot.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1457429-help/#findComment-15580569
Are you just determined to use the same brand of RAM and the same brand for your new GPU because you like the way they look, or...?
As already mentioned, the 7700 can only deliver entry-level performance by 2022 standards. You should probably be thinking about how much money you want to put into this system versus starting a whole new build.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1457429-help/#findComment-15580843
I'm going to update it to at least an intel 12th Gen cpu. Sorry for not mentioning that earlier. But yes I am looking for specific brands to keep the new build as close to the old build as possible for nostalgia purposes while also keeping my performance high.
Also thank you for the feedback!
https://linustechtips.com/topic/1457429-help/#findComment-15582423
Maybe just build a whole new rig to daily drive, using parts that are easier to find, and keep your first ever custom PC intact for sentimental value?
Main rig:
CPU: AMD Ryzen 9 5900X
GPU: Sapphire RX 6800XT
RAM: 2x16GB DDR4
Motherboard: Asus ROG B550-I
Storage: 2TB Samsung 980 PRO NVMe, 4TB WD Blue HDD
PSU: Corsair RM850x
Case: Fractal Torrent Nano
OS: Linux Mint 20.2 Cinnamon
NAS:
CPU: AMD Ryzen 4600G
Motherboard: ASRock Rack X470D4U
RAM: 2x16GB DDR4
Storage:
  • Boot: 16GB Supermicro SATADOM
  • Pool 1: 2x6TB WD Red Plus HDD mirrored, for bulk storage
  • Pool 2: 2x500GB NVMe SSD mirrored, for apps like Plex and Adguard Home
PSU: Be Quiet SFX-L 600W
Case: Silverstone CS351
OS: TrueNAS SCALE
https://linustechtips.com/topic/1457429-help/#findComment-15583179
