Need Help Deciding!
I am currently on the market to buy a monitor for my PS5. My goal is to get 4K resolution and 144hz refresh rate (120fps for ps5).
I mainly play more story driven games hence the higher resolution, but I also like to dabble in FPS games.
My budget would be about 900 USD but I am from New Zealand.
Any recommendations would be greatly appreciated 🙂
Edited by Eef
budget change lol
https://linustechtips.com/topic/1456692-need-help-deciding/
Since that's out of your budget, either save up more money or settle on a 1080p 144Hz monitor. 1440p won't do you much good since the PS5 doesn't support that resolution. Or look on the used market. Maybe you'll find a used Samsung Odyssey G8 4K or a similar monitor.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1456692-need-help-deciding/#findComment-15575567
If I raised my budget by $500 what would you recommend?
https://linustechtips.com/topic/1456692-need-help-deciding/#findComment-15575570
They do now, but with a bit of downside.
https://www.msn.com/en-gb/lifestyle/shopping/ps5-update-adds-1440p-output-e2-80-94-with-one-big-caveat/ar-AA11Cfat
So yeah, better save up some more for a decent 4K monitor.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1456692-need-help-deciding/#findComment-15575571
If you can afford it, go for this one: MSI Optix MAG281URF 27.9" 3840x2160 144 Hz Monitor (Optix MAG281URF) - PCPartPicker
That seems to be the cheapest good option in NZ.
https://linustechtips.com/topic/1456692-need-help-deciding/#findComment-15575578
