1 minute ago, naithehunter said:
i recently built my new pc and it has the DRAM light on how do you fix that and is there info I need to provide so someone can tell me?
Full specs would help us to help you, but a good early check is to verify your RAM SKU is on the board's QVL list for the processor you have, especially with Ryzen. RAM instability can be quite a big deal with Ryzen.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1456286-dram-light/#findComment-15572429
specs are
https://pcpartpicker.com/list/3Nb33y
i7 12700k
Msi B660 mortar
corsair vengance ddr-4 3600 ram ( 2x -16 )
samsung 970 evo plus 1tb ( SSD )
MSI geforece 3060 ( 12 gig )
as of pc part picker everything is compatable but idk if it actualy is to be fair
https://linustechtips.com/topic/1456286-dram-light/#findComment-15572435
Check your Mobo CPU socket. Resit the CPU. As well as your RAM. Make sure to not tighten down your CPU Cooler too much as it can also give these errors. If you suspect RAM you can always test it in another PC if you have one the same DDR version around.
https://linustechtips.com/topic/1456286-dram-light/#findComment-15572458
3 hours ago, naithehunter said:
specs are
i7 12700k
Msi B660 mortar
I'm told this is a much bigger deal with Ryzen than Intel, but it appears your RAM's SKU of CMK32GX4M2D3600C18 is not on your motherboard's Qualified Vendor List. As such, 100% stability and compatibility cannot be guaranteed. So if everything else checks out, that's a possible culprit. And I've seen some very crazy issues with DIMMs, some even failing after testing fine.
https://linustechtips.com/topic/1456286-dram-light/#findComment-15572546
