My hard drive isn't detected in bios, I've updated bios and tried everything, however I have an old seagate barracuda which when plugged in boots into windows (I have no idea which version) , I think I need to replace my newer one since the sata plug might scuffed, any help is great
Thanks in advance
Part List:
https://uk.pcpartpicker.com/list/QnnpFg
BIOS VERSION - 63c
https://linustechtips.com/topic/1455634-hard-drive-not-detected/
22 minutes ago, EinsteinJr_ said:
Oh yeah always remember to never use other power cables, use the one the PSU comes with.
100%. when doing PSU swaps I don't even open the new box til I've yoinked all the old cables.
Have you tried the drive in a different tower? Also try with a different SATA cable as sometimes they will flake out only on some drives.
TBH my guess is dead drive.
I don't think it's dead since when I bought it they tested it and it worked but it was plugged in via USB. But I will use another sata and see if that works
