First Build, not turning on
Go to solution Solved by Rivettz,
1 minute ago, Tisori said:
Alright! Good news, everything seemed to turn on, including the M&K. However the monitor still said no Display Port signal.
Mess with the active display port in the monitor settings, Those buttons on the side of the monitor
So I've been following the video LTT put out and I'M at the point where they say to test it all before putting it in the case. I flipped the PSU on and I can tell it's working because there are some rgb lights on the motherboard now. Nothing's making any noise which I don't know if that's a problem or not but when I turned the monitor on it flashed a blue screen that said the HDMI cable isn't plugged in. Earlier someone else told me that only the Display Port had to be plugged in. Does anyone have an idea of what the problem could be?
https://linustechtips.com/topic/1455446-first-build-not-turning-on/
Is the monitor set on the right input?
Marline
Top Loop:
Thermaltake Pacific PR2U Dual 5.25" Bay D5 Pump/Resorvior Combo / EK ZMT Tubing / A mixture of Chrome Plated Brass Rotary Fittings Bit Fenix and Alpha Cool / Alphacool NexXxos 280mm 45mm Thick Copper Pass-through Radiator / Alphacool NexXxos 140mm 45mm Thick Copper Radiator / XSPC G1/4 1/2ID Chrome Compression Fittings / Freeze Mod AM4 CPU Waterblock / 3x Noctua Redux 140mm fans
The Bottom:
Custom Made 2mm Thick Steel PSU Shroud / Aqua Computer Aqua Tube POM Reservoir / Alphacool Eisdeck 5 w/D5 655 Pump / EK ZMT Tubing / Alphacool 45° Chrome Plated Brass Rotary Fittings / Bitfenix 90° Chrome Plated Brass Rotary Fittings / Alphacool Chrome Plates Brass Pass Through Fittings / Koolance QD3 Quick Disconnects / Bitfenix Full Cover Water Block 2080ti / Alphacool NexXxos 200mm 45mm Thick Copper Radiator / Noctua Chromax 200mm Fan / The fluid I used for both was EK Cryofuel Acid Green
Computer Specs:
Thermaltake F31 Suppressor / Ryzen 9 3950X / 32gb G. Skill 3200mhz RAM / Asus B550-E motherboard / Zotac RTX 2080 ti 11gb / EVGA 1000 GS PSU / Samsung 970 Evo Gen3 NVMe SSD / Western Digital SN850X Gen 4 NVMe SSD / 4x PNY 120 gb SSDs in RAID 0 / 1x Spectre 512gb SSD / 1x Patriot 240gb SSD / 1x 1Tb Western Digital Black 7200RPM HDD / 1x 2Tb Seagate 5400RPM HDD / Windows 10
Just now, Tisori said:
I'm embarrassingly technology illiterate. What does that mean exactly and how would I change it?
Oh you're all good. We all started somewhere. On the monitor itself there should be some buttons. One of them is  for the inputs on the back. Press that button. If you tell me what monitor it is I can look up what button you need to push.
Marline
Top Loop:
The Bottom:
Computer Specs:
Does your motherboard have a Display port input? If so, make sure you do not plug it into there, plug it into the Graphics card.
Don't sleep on sleeper PCs
Thanks, it's an ASUS TUF GAMING VG27A
You didn't actually turn on the computer, you just turned on the PSU. Which provides standby power to the Motherboard, usually by default RGB will light up in standby. Unless you're saying that you actually shorted the power pins on your motherboard with a flathead to try and turn on the system outside of the case.
My main rule is. Never be afraid to look at the manual. You're not less of a man if you do, There is a reason why its there in the first place.
On page 10 it tells you what the buttons on the side mean. Press the top button to access the active port.
https://gzhls.at/blob/ldb/2/f/5/1/8d5d1bdcf4da79032568ded67206a52e336b.pdf
Marline
Top Loop:
The Bottom:
Computer Specs:
Okay, I switched it to display port but now it's just saying no display port signal
Okay great. Is the machine plugged in and actually turned on? You may need to jump some pins with a screw driver to actually turn it on
Marline
Top Loop:
The Bottom:
Computer Specs:
I mean, the PSU has a power switch so yeah it's on
Okay Awesome, The machine is ready to be turned on. Send me over the Motherboard you are using because you may need to jump the power pins to see if it all starts.
Marline
Top Loop:
The Bottom:
Computer Specs:
Motherboard is a TUF GAMING X570-PRO(WI-FI). Also ASUS
On page 33 of the Manual for your Mobo youll see a set of pins called the System Panel Header.  You're going to want to jump the pins labelled 'PWRSW' With a screw driver. Do this only if you have a CPU Cooler installed along with all the RAM and other essentials that are hooked up to the Motherboard.
https://manuall.co.uk/asus-tuf-gaming-x570-pro-wi-fi-motherboard/
Marline
Top Loop:
The Bottom:
Computer Specs:
@Rivettz @Tisori
Like I stated 7 posts ago. The system is not powered on. The OP just flicked the PSU switch on. This does not turn on the computer.
Okay, I see what you're talking about. What do you mean when you say "jump" the pins? As an aside if you think pictures of anything would be helpful just ask.
Marline
Top Loop:
The Bottom:
Computer Specs:
5 minutes ago, Tisori said:
Oh lol I meant pictures from my end. So just touch the pins with a screwdriver? That pic isn't very clear
Yeah the pins in the manual on Page 33 Labelled 'PWRSW'
Marline
Top Loop:
The Bottom:
Computer Specs:
Ok yeah, I saw a video on it and it looks pretty simple. Just because I'm overly cautious, how do I turn it back off to put it in the case? Just turn off the PSU or what?
Yes, Flip the PSU to the off position when youre finished
Marline
Top Loop:
The Bottom:
Computer Specs:
Marline
Top Loop:
The Bottom:
Computer Specs:
Everything finally worked, I got into the BIOS, and I think I'm good to go now. Thank you so much for all this help, I know it was probably frustrating. Now I just have to take it all apart, put it in the case and do this all over again... *sigh*
Im so happy to hear that! I hope its a solid machine for you friend. Good Luck in you PC Endeavors
Marline
Top Loop:
The Bottom:
Computer Specs:
