I've seen a bunch of fitting types (ex. compression, monsoon, etc.) what do these mean? I know everyone says get compression, but what does this mean? Just looks, or reliability?
Intel i5 4670K 3.4GHz | EVGA 780Ti Classified | ASUS Gryphon Z87 w/ Armor Kit | G.Skill Sniper 8GB @1866MHz
Samsung 840 Evo 500GB | Seagate Barracuda 3TB | Kingwin Lazer 850W Bronze PSU | Corsair 350D Window
Razer Blackwidow Ultimate BF3 Edition | Razer Naga Molten
https://linustechtips.com/topic/145488-difference-between-fittings/
monsoon is a company
you have 2 types of fittings, bards which need zip ties to make it not spill water all over your precious PC parts
and there are compression fittings, where there is a ring that you screw over you fitting that makes not spill water all over your precious PC parts, which obviously looks better and are used in almost all PC watercooling builds
also, monsoon is generaly more expensive than more well know brands
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Compressions fittings are a barb fitting with a screw on cap that secure the tubing in place. It looks better than a barb and there is less risk of the tubing slipping off.
Monsoon is a company that produces premium compressions fittings, just like bitspower.
Edit: ninja'd -_- & typo
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
Compressions fittings are a bard fitting with a screw on cap that secure the tubing in place. It looks better than a barb and there is less risk of the tubing slipping off.
Edit: ninja'd -_-
wait, monsoon is a premium brand? i thought they where cheaper -.-
EDIT: DAMN they are expensive!
They're premium priced, but no better quality wise then any of the other Chinese OEM's
Err, have you ever used monsoon products, I can assure you they have better paint and finishes on their fittings than cheap fittings.
Monsoon are quite unique with their look and choice of colours. You can see the tubing through them, but they are very expensive.
"bard" fittings have been mentioned but the actual name is "barb" fittings.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
Glad to hear this! Just bought some!
Enthoo Primo - ASUS Maximus Formula VII - 4790k 4.8ghz 1.28v - EK Supremacy Evo Clean - 16GB Crucial Ballistix Tactical - 1000w EVGA Supernova Gold - 2x Alphacool Monsta Rads in push/pull - 2x Galaxy 780 HoF with EK waterblock
Build Log http://imgur.com/a/UV6Wh Just want to warn everyone, my build log is pretty mediocre.
