I looked into this shortly but seemed out of my expertise, could someone explain or enlighten me of a way to boost the wireless signal of a headset like the corsair hs80?
I just wanna go from talking on discord and in between rounds just get up and go smoke a cigar or something outside which is maybe 15 feet away from the PC but the walls are cheap concrete  but the distance isn't far and my location of the dongle for the headset is already 6feet raised into the air.
Just wondering if someone can enlighten me of any product im unfamiliar with.
Thanks in advance lads
https://linustechtips.com/topic/1454758-wireless-headsets-range-boosters/
I suspect you're out of luck, short of using your phone and plugging a headset into that instead.
Bluetooth headsets can sometimes have better range on a desktop PC by using a higher gain WiFi antenna, but ones with their own dongle are probably using their own protocol and a lot more bandwidth, so range is limited.
