Hello.
I found a new Zotac Mini PC, MAGNUS EN072070S with a i7-10750H and a nVIDIA GeForce RTX 2070 SUPER, to be exact, for really cheap.
I want to ask people around here, is this a good choice for a home gaming PC? I have a 1050ti and a i5 3470 now, and its incredibly hard to find anything better than that around where I am. It's for less than the price of that GPU, and with RAM and storage, counted all together.
What are your thoughts? Is this a good buy? I know its hella better than mine now, but are thermals an issue with it? Or any other bad things going around those mini PCs? I dont mind playing with lower graphics for the sake of 1080p high fps.
Thanks.
https://linustechtips.com/topic/1453615-zotac-mini-pc-question/
If you can get it cheaper than a normal size PC, it'll work but I wouldn't personally choose a mini PC.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1453615-zotac-mini-pc-question/#findComment-15553643
I have always used a Mini PC just because space is at a premium in my office. But you should keep in mind that you'll get a bit worse performance than you'd expect from the same components in a larger case with more airflow.
So take a look at the performance characteristics of laptops with this CPU, GPU, and RAM combo as well as full sized desktops and you can get something of a feel for what to expect.
https://linustechtips.com/topic/1453615-zotac-mini-pc-question/#findComment-15554510
On 9/5/2022 at 6:46 PM, VirusWar said:
Hello.
Thanks.
Whats the price? Keep in mind this is a laptop in a desktop basically. It also seems to have trouble handling the heatload so expect even lower performance than normal.
Best compared would be about a desktop rtx2060 + ryzen 2600 which are systems that go for about 5-600$.
So unless you really need this mini pc Id not get it as you'll end up with a not upgradeable piece of hardware where the cpu will still be good but the gpu will start lacking. Also doesnt help it overheats day 1.
https://linustechtips.com/topic/1453615-zotac-mini-pc-question/#findComment-15555832
Rtx 2060 costs around 800usd here, so that calculation Is out of the window.
The store I'm following has some kind of a all out sale for zotac, idk why, but all their stuff is dirt cheap. From 1500usd down to 800usd (Still almost half over my salary)...
I found ZBOX-ECM53060C-BE also really cheap and I am now thinking about that. It's a full size GPU from what I can see and should be much better at cooling compared to the one I posted in the OP.
Thoughts?
Thanks for all the answers
https://linustechtips.com/topic/1453615-zotac-mini-pc-question/#findComment-15558113
