Hi,
This is my current part list: https://pcpartpicker.com/user/rvukasin/saved/#view=GZN4pg  (3090 is on the way, still using 2080 Ti). As 2080 Ti can get hot in this case I was thinking of buying a new one. I need a good airflow case and I don't mind buying additional fans to increase performance. I am not interested in looks as it is under my desk anyway.
I would also prefer to have more than 2 normal USB-a on the front panel.
Any suggestions or pointers? I am looking for something future proof.
https://linustechtips.com/topic/1452930-help-chosing-the-pc-case/
if airflow is what u want, check out fractal torrent compact
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
There will be many opinions on this, mostly concerning airflow, and rightly so, as the 5900X has more challenging cooling demands. However, it does not require liquid cooling, I air-cool one in a Fractal Design Pop XL Air (the lower-mount ODD bay was what sold me on it). But to be fair, my build (sans Pioneer Blu-Ray drive) was previously in a Corsair 4000X, which kept my 5900X and RTX3060ti-8GB-OC in check, running PBO and OC modes, respectively. And that case has just 34 sq inches of intake. So while airflow is important, you need not have the volume of the Holland Tunnel for effective cooling.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
I had a 2080 ti and replaced it with a 3090.
The 3090 is much harder to cool and all my traditional high airflow cases were a fail.
The cases that were successful are ones that could intake air below the GPU.
For my build using a Noctua NH-D15 it is a Lian Li o11 Dynamic EVO.
The only other type of case I would use is one that can exhaust out the bottom like the Fractal Torrent.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
6 hours ago, An0maly_76 said:
Pop XL Air
btw did the pop xl stock fans work for u or u had to swap em?
+1 for the Torrent Compact. Awesome case. Take your time with cable management though. A lot of reviewers complain about it, but they have a timeline to work with.. if you take your time it’s an awesome case. For simple builds it’s super easy to work with.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
I'm sure the three or four stock fans included will work fine for most people. However, I already had six LL120s and a Commander Core XT, so I went ahead and swapped them anyway.
That being said, if you want to add more, they will be hard to find individually for at least a couple more months, so I have four brand-new ones if anyone needs them. Just make me an offer plus shipping.
I have the exact same CPU/MOBO/D-15 as your list and I run a Lian Li Lancool 2 Mesh and its fantastic.  Very easy to build in and extremely versitile.  I just bought the Lian Li Lancool 3 for a custom water loop im converting mine into and wanted more room for larger radiators but for air cooling the Lancool 2 Mesh is fantastic.
